DR-25 vs SE28 Visual Differences
1519 Vistas
I am currently building a harness and am about to order the sheathing for it. I am located in New Zealand and there currently seems to be a shortage of DR-25 and a particular size of SE28. How visually obvious will it be if i use a combination of the 2 heat shrinks? The DR-25 i have access to is white label color at least. It is an open wheel vehicle so a good part of the loom is visible.
Only visual difference I noticed is the brand stamping.
