earth bonding
Módulo relevante: Habilidades prácticas de diseño de arneses de cableado > Diseño de puesta a tierra
1164 Vistas
hi there
sorry to ask but i am abit confused. so for the efi system, i made a connection from the negative side of the battery to the chassis and then i passed a seperate wire wire from the negative side of the battery to the engine block. like that is ok please?
That should be fine IF all the ECU sender electronics use the same ground point.
duplicate topic, closed
