Hello Everybody!
Im planning to do a engine harness for my RB25 in s13. I would like to ask more experienced motorheads if my way ofthinking is correct and if Im going the right way.
1. Im planing to do MAIN REALY wich will be triggered by ignition switch from "barrell".
2. "MAIN RELAY" will switch relays for : colis, injectors, cooling fans, fuel pump. (please see attached simple scheme)
3. From "gearbox harness" do i need only vechicle speed sensor to be connected to EMU ? (PIN 20 in black connector)
4. Please feel free if You think i can add something more in the pin out of EMU BLACK (see attached)
Thank You very much in advance.
Tomasz
