ign switch
1481 Vistas
Can i use motec c125 digital input for ign switch or it need to wire from ecu only
Which ECU are you using? With the M1 ECU's you can run the switch into a Dash and then transmit this channel into the M1 over CAN and use it as the Engine Run Switch.
im using m150 btw. what about front wheel speed sensor and paddle shift using ignition cut function,what’s the difference between 1.connect through c125 using can to communicate 2.connect directly to m150.does it have some kind of signal delay that i should worry.
