Jeep TJ OEM dash with standalone ECU
1684 Vistas
hello has anybody able to connect the oem dash from a Jeep Tj with a standalone ecuor do i need to keep the oem ecu parallel with the standalone
This may not be the same application but I would think the same principles apply. I ran a standalone Motec M400 in my Evo and used the stock dash. I had to use one of the Aux outputs for the tachometer output. The rest of it was retained through the OEM harness.
Maybe adding some more info would be helpful for someone else to chime in. What ECU are you running, what year Jeep, and what do you want to retain on the stock dash?
its a 2000 jeep TJ with an ls3 engine im using the haltech rebel ecu.
