Link loom and dr-25
646 Vistas
About to make my first harness, i have got the link ecu loom a+b to simplify things. I cant find a temp rating for the wire used. Has anyone had experience with this and using raychem dr-25 if it will damage the wires shrinking it? Also if theres any other products that might suit better, im not a big fan of the braided style ones.
Link uses AVSS/JIS standard wire similar to TXL if memory serves. I think it's rated at 120*c - if you're heating it through the DR-25 it'll be fine.
