Load signals
1250 Vistas
What is electrical load and power steering load signal? Where do they come from and does my R32 Skyline have them?
Hello
your r32 has may have steering load and electrical load depending on what ecu you are using
power steering load is a pressure sensor plumbed into the pump high-pressure line and wired to a Digital input in the ecu when load comes on to the high pressure line it triggers the di to up the idle speed to stop stalling and same with electrical load from fans
Regards Ross
