margin of error
1130 Vistas
I noticed that each of the power supply wires here are not cut "exactly" to length here, What over-run percentage was used as a safety margin/margin of error?
I typically add 3" at each end with a connector, but the professional harness (concentric twist) suggest 20% to allow for twisting...
