Motec M150
2219 Vistas
Hey Guys
Need some help choosing the following sensors that maybe Motec already has the calibration for.
Preferably with variable thread fitments to choose from.
Oil Temperature
Fuel Pressure
Oil Pressure
TIA
Chris Taylor
Load M1 Tune and configure the sensors -- in the Calibration you will see the choices for sensors that have calibration files, plus manual allowing you to fill out the translation table yourself. I would expect that your MoTeC dealer can probably supply sensors they typically use (which means you know where to go to get a spare).
Thanks David
Will do. This a car I've come to where everything has been bought before I got there.
Trying to get it finished and started for him as he has bee waiting 2 years after being messed around massively.
