Need help identifying pins
852 Vistas
i have a 3 pin Toyota 4y coil pack the pins are marked A B C anyone know the wiring layout ?
Should be in the factory workshop manual. You should not take on an engine project without the factory workshop manual.
The factory service manual for the vehicle/engine the coil comes from will generally have a diagram showing the pin arrangement.
