Need Help Identifying Terminal Pin
676 Vistas
Hi all,
Anyone able to identify the type of terminal pin referenced within the attached photo? If so, any suggested manufacturers or websites? I'd like to utilize the existing OEM connector and need to source terminal pins (male/female).
Thank you
Chris
Thank you David, ended up reaching out to bmotorsports and they didn't have my exact terminal. The links you referenced seemed pretty spot on, but apparently they don't have them.
I may end up just using a DTM connector and repinning male and femaile terminal pins.
