Oem intergration
2215 Vistas
Hi I have a jza80 supra with active areo
Would a link fury be able to output a power ground to activate areo at 80km/h
So you just want a ground signal at 80kmh? That will be no problem. The Aux outputs are only capable of 2A so if it needs more than than that you will need a relay involved also.
Nicholas,
Link ECU`s and in particular Link Fury are able to activate a variety of systems with AUX outputs or spare ignition/injector outputs. The only thing is to consider is that this outputs are a low current outputs and for high current circuits operation must be used via 12V automotive relay.
