power distribution
1748 Vistas
Does my injectors and coil packs share the same relay?
Providing some actual information on your vehicle, the engine management, etc. would be helpful - that's the equivalent of asking if a piece of string is good enough.
Here can you see how i did it if you havn´t got the answer you needed
https://www.hpacademy.com/forum/practical-harness-construction-club-level/show/what-do-you-think-my-second-harness
