Hi,
I am wanting to set up my Motec CDL-3 to display ethanol content and fuel temp as per the article, you show the CDL-3 input pin settings using DIG1 (ethanol content) and SPD3 (fuel temp)
My question is:
Do both inputs get simply connected together to the ethanol content sensor output? Or is there more to it?
Thanks,
Brent
Yes both inputs are connected to the same sensor output. You are just measuring two different aspects of the same signal using two different inputs.
Thanks very much David.
