RB25DET Blue Plug Pin Part #
539 Vistas
Anyone know the part numbers for Nissan 76pin blue plug ecu connector pins (big and small) on the engine harness end? Need to do a Neo grey plug swap to blue plug.
Thanks Sean"Nissan RB25 Loom Side Header Plug Suit RB20"
Wiring Specialties have a kit with a few big and small terminals. There is info out there for the actual manufacturer part number to buy them from places like Mouser but you generally need to buy in lots of 100 or more. If its just the one project, Id recommend the below.
https://www.wiringspecialties.com/nissan-blue-oem-ecu-connector-pin-kit-10-pc/
