Source for quality ring terminals and bullet terminals
1527 Vistas
I am looking for info if possible for a good source of PIDG ring and bullet terminals.
The reason behind wanting bullet terminals is that I have a 1973 corolla that uses them for the number plate lights only. There is a pair of factory holes behind the bumper that won't allow me to pass anything larger than a typical bullet thru it and I don't want to hard wire theses lights in for maintenance (old cars right)
I have a Pro Crimper III hand tool with the PIDG die hence the specific reference. Any help is appreciated (I tried TE Connectivity but there web site is US based and doesnt offer shipping to NZ)
Thanks
If you are already using DT connectors elsewhere, have a look at Deutsch Jiffy splices. Uses the same terminals/tooling but very similar dimensions to a bullet terminal.
Perfect!
That was the information I was looking for. Thanks Rob.
