SR20 Wiring Documentation Sanity Check
2530 Vistas
I have filled out the Club Sport Wiring Documentation. Would it be possible to review my documentation? I have numbered the pins as if you were facing the connector (mating side) with the locking tab up, with the exception of the wideband (diagram is attached to document). The motor is a s13 sr20det to be run by an aem infinity 506.
Verification
wire size
Connections to ecu, and if possible connections to components
Off topic question: is there a standard for numbering terminals in connector housing? I am thinking it should be looking at the back of the connector, locking tab up top left to right, down a row left to right. ( i did it opposite... but hey we learning)
  • Rickys-510.xlsx
G'day Drew. I'll try and find a moment to have a look at this later on.
For connector numbering, its usually defined by the connector manufacturer, and will be embossed on the connector itself. Best to follow that scheme, as it'll save you confusion when its time to terminate the harness to the connectors.
