Star Earth Grounding
1835 Vistas
So what about when your battery is relocated to the trunk? Would it be correct to run negative cable to body and then body to block? Or is the best option to run a 2 gauge cable all the way to the block to do it how it's outlined in the class?
It's sufficient to fround the battery to the chassis and then the chassis to the engine block.
