- star point/mag pick-up
899 Vistas
With the negative star point is it acceptable to use a floating/insulated star point in the cab running to the star point off the motor
Is the magnetic pick up of an MSD ignition system subject to interference, when run in conjunction with water pump/Themo fan, oil pressure Alternator main wiring/field wire
