Supplier for OEM terminals
1036 Vistas
Hi all,
I'm working on a project where i'm re-using some of the factory wiring for an engine swap. There are unused fuse and relay locations in the standard fuse box that I want to use, and am trying to track down the appropriate terminals. I'm in Australia btw.
I've already done a fair bit of research and tracked down most of the part numbers for what I need, but finding where I can get these from is proving to be a bit more difficult than I had hoped.
The donor vehicle is a 2005 LS Ford Focus, engine is 2.0L Duratec HE. These are the terminals i'm chasing:
Jcase fuse male 6.3mm - Lear 3202569T6 Jcase terminal
Female terminal 2.8mm for ISO 280 mini fuse - for 1.4-2.0mm2 - Lear 320100365, for 3.0-5.0mm2 Lear 320100373 ISO 280 fuse terminal
Female terminal for ISO micro relay 6.3mm - for 1.5-2.5mm2 - Lear 320100431, for 3.0-6.0mm2 Lear 320100472 ISO micro relay terminal
Thanks!
Damo.
Corsa Technic has sourced me those 2.8mm Iso fuse terminals in the past, I'd message them.
Tell them I sent you haha
