Suzuki 1.6 16V G16B Crankshaft Position Sensor Connector
1485 Vistas
Hi,
Does anyone have ideas where I can source the connector for a Suzuki 1.6 16V G16B Crankshaft Position Sensor. I have a Haltech ECU with flying leads on order and I would like to buy the connector with pins so I can attach directly to the flying lead wiring rather than resorting to using the $50 Standard S-2334 pigtail.
The Standard S-2334 pigtail does fit, but I would like to avoid a joint in my new wiring harness on such a critical sensor. If I can't get the connector housing, It would be nice if I could at least source the pins and rubber seals so I can re-pin the pigtail connector.
To me it looks like Sumitomo connector like this one:
https://www.bmotorsports.com/shop/product_info.php/products_id/2327
or maybe this one:
https://www.bmotorsports.com/shop/product_info.php/products_id/2281
Best bet is to measure the pin widths, and connector housing sizes, send info and pictures to Ballenger Motorsports, and ask for their help identifying it.
They also sell terminals & seals, but not sure if they would fit the Standard S2334 housing...
Thanks for that. After looking over the Standard S-2334 'm pretty sure it's the Sumitomo connector. The pins are a more a bit more rectangular on the Sumitomo connector vs that other connector. The colors also match on the plastic bits, which may be a sign they came from the same production facility.
Funny thing is that this will be my third order from Ballenger in two days. They seem to have most of what I need for my custom harness. For those of us in the US, Ballenger is a good choice.
