tidily hand drawn document
1470 Vistas
Hi All,
I noted there was no main fuse in the "tidily hand drawn document."
I was thinking of a main 70amp fuse or is overkill?
If you could provide a link to the document in question, please, it would make replying much easier?
Do you mean on the main feed from the battery? 70A may be a little high but shouldn't hurt, 50A may work just as well. Because I loathe voltage drops, make sure the wire gauge is adaquate with a minimal voltage drop along it.
I do like each circuit being fused, but my preference is to fuse the main supply to the relay(s) rather than after, or a fused relay/circuit breaker, but that's me and I like to have them as close to the source as practical to protect more of the wiring against shorts.
Thanks, Gord, that lines up with my thinking.
