toyota jz alternator sense connector
547 Vistas
what would be the appropriate size wire gauge to run for the 3/4 pin sense connector?
20–22 AWG is perfectly fine for the 3/4-pin alternator connector. Those circuits are only sense and control inputs to the regulator, so the current draw is very low and there’s no need to run larger wire.
That's what i was thinking. Thank you for the reassurance
