Twisted wire
1505 Vistas
I thought all the wiring will be twisted together
What The difference between this type of wiring and twisted type ?
If you're referring to 'concentric twisting' then no, it's not a technique we use at this level of harness construction since the time and cost can't be justified for a club level harness. If you want to learn about the technique we cover it in our professional motorsport course.
