TXL wire source and sizes
3115 Vistas
Your scheme for wiring is as follows (put here so it is more easily searchable)
Wire size chart: https://www.powerstream.com/Wire_Size.htm
TXL wire with sizes I selected
Power Supply - red (16ga)
Power Supply - black (16ga)
Sensor Supply - orange (20ga)
Sensor Ground - green (20ga)
Other Wires - white (20ga, 22ga)
CAN H - white (22ga)
CAN L - green (22ga)
Please respond if you would suggest I buy something different. Also please respond with where you sourced your wire.
Your sensor supply and ground wires usually wont need to be 20AWG, 22AWG is typically fine as they dont usually draw much current.
All my wire was sourced from Waytek Wire, in the states.
