Which Deutsch connector.
553 Vistas
Injector sub-harness. 8 x ID725 injectors individually wired for sequential operation with 4 x 12v feeds paired such that no two injectors will be drawing from each feed simultaneously. Can be all connected via a single 12 pin connector. The question is....DT or DTM?
DTM will handle this easily and it's smaller.
Thanks David. Figured as much. Just wanted confirmation. Cheers.
