Wideband current draw for wire sizing
4696 Vistas
i am currently wiring up a fuse box for a project that is running Fueltech ecu and dual wide band modules.
I cant seem to find the current draw for my wire sizing.
Is a single 16awg (MIL-W-22759-16) enough to supply power to both wideband modules?
Thanks
Yes. We often use 18-20 awg each.
Thank you
To be more specific I tend to see ~.8 amps draw on LSU 4.9s. Initial inrush when the heater snaps on is usually around 3 amps. This is using motec gear and heating strategies. On this specific vehicle: pdm15, M600, onboard o2 controller.
