Need a basic ECU, fuel only, for a single cylinder two stroke motor (250cc), single crank pulse.
Any recommendations?
TIA
You might check to see if the AiM Taipan would work for you.
https://www.aim-sportline.com/us/products/ecu-taipan/compatible-models.htm
maxx mini, microsquirt, link atom-x, or elite 550 would be my approached options
NOT something I have tried, or even investigated, but you "may" be able to use the alternator ripple, or a single winding's voltage variation, as the crank sensor's signal, if you can clean it up, and the single crank pulse as the TDC position reference point?
