Balancing Question
1209 Vistas
I am doing a build for the first time a d I won't be able to balance the Conrod ends however I will be able to balance the piston set. Should I just focus on balancing the piston/wrist pin or can I mix and match the heaviest Conrod with the lightest piston to achieve a balanced piston/conrod/wrist pin assembly. Thanks!
Hi Hunter, if you mix and match to find the closest matching total weight of all three parts would be your best bet
Regards Ross
