Divide by two?
1246 Vistas
Is oil clearance simply (Block inner diameter) - (crank journal outer diameter) or is it defined as ((Block inner diameter) - (crank journal outer diameter)) divided by two, to represent the clearance on either side when rotating?
The total.
EG, journal (outside) diameter 50.000mm, bearing (inside) diameter 50.064mm, clearance = 0.064mm.
Thanks!
