How do you work out your ring gap to the boar
Módulo relevante: Habilidades prácticas de construcción de motores > Espacios entre anillos
1332 Vistas
Ring gap
Seriously?
You check the manufacturers' recommended gap per inch, or cm, for the application, then multiply that by the number of inches or cm the bore is.
However, if you have a wild pig that you want to ring, say through the nostrils, I'm relieved to say you're going to have to write to a more specialised forum.
