What about cleaning injectors?, I've seen all the example but found nothing about, since are electromechanical components I don't think ultrasound is a good way...
Maybe a suggestion or how you do, to clean parts "in house" (removing liquid seal, rust, ecc) will be appreciate ;)
Hello Massimo,
Ultrasound cleaning is actually a very very efficient and thorough way to clean injectors and has been used successfully for many years as the prefered way to clean injectors, in conjunction wth backflushing leak testing pressure testing flow testing and injector matching, this makes for the best results to be sure you have a clean and even fuel delivery.
