K20
Módulo relevante: Introducción > Cómo utilizar este curso
1273 Vistas
Please do a Honda k20 series course I really need this!
There are quite a number of people posting their builds, problems, etc. on Youtube, and elsewhere.
Do you have any specific areas where you need help - depending on just how far one wants/can afford to go, you're looking at anything from a couple of hundred to over 1500hp? Not forgetting the rest of the support required, which may be anything from a mild re-tune to up-rated fuel systems, clutches, transmissions, driveshafts (can be a big problem), etc.
If you haven't done so, buy or d/load (a) vehicle(s) workshop manual(s) with this engine, which will give you the basics.
The forum is here for specific questions not covered in courses you've already taken, so if you have something to ask please let us know.
