line hone? minute 1:00
1264 Vistas
Around the first minute of this video you suggest getting a "line hone" with ARP studs attached, allowing for any warpage of the block by studs. And then I hear no mention of this step the rest of the worked example.
Are you saying you delivered the block to the machinist with heads attached with ARP studs for them to do this??
Please clarify, this has me very confused, when I feel like I'm grasping everything else well...
See your updated post.
