LS1 worked example
2320 Vistas
Hi Team
just wondering if you have a full parts list for the build ie the K1 stroker part #, the dampener, timing chain, head gaskets etc as well as the machine work carried out, you mentioned the block had been decked etc thank you and can’t wait to see it run.
Hey Ashley, sorry i don't have a full parts list but can probably put something together. It's a good idea. Right now I'm sorry but I'm snowed under so I can't promise anything in the immediate future. The machining tasks however are described within the worked example.
Hi Andre
+1 on the parts list for this, if you can.
Cheers
