piston ring
Módulo relevante: Ejemplos resueltos > Toyota 2JZ > Step 7: Short Block Assembly
864 Vistas
i dont see how to set the piston ring in the modules?
What do you mean?
Setting the gap, installing on the piston, the order, the type, the gap orientation, or what?
