Ring gaps
Módulo relevante: Habilidades prácticas de construcción de motores > Espacios entre anillos
880 Vistas
Im currently building a l84 engine from a 2023 Silverado 5.3, Simeone else took the engine apart, The client bought Oem pistón rings and the gaps are 0.25m.m For the top compression ring and 0.55m.m for second compression ring.
But Im not pretty sure which ring should be the first one, may dum question but I want to make sure
Not sure if is the one with the Orange mark or the silver one.
Cheers
