Rod bearing cap
Módulo relevante: Habilidades prácticas de construcción de motores > Medición de la holgura de la plataforma del pistón
1145 Vistas
Hi,
When measuring the the rod bearing clearance, do the rod end caps need to be torqued or simply nipped up ?
Thank you,
Kal
[edit] It's a good practice to torque them, or set them to stretch, because the rod material may compress slightly under the clamping force of the bolt/stud.
If using aluminium rods, it's a must!
Hold the rod in a vice, just below the mating face with some "soft jaws" to make it easier, and without damaging the rod - if you don't have them, a couple of lengths of aluminium angle will do the job.
You can buy specific 'rod vices, but if you're not doing this on a regular basis, it may be an un-needed expense.
