Sr20ve rockers
2406 Vistas
Just checking the best way to actuate/ lock the rocker for high lobe on camshaft to degree cams.
There is a rocker arms stopper in the aftermarket dude!!!
I have never seen one in bits, but it looks like you could slide a rod or drill bit up the centre hole of the pivot shaft to lock the centre lobe activation pin out.
