Torque specs 3sfe beams engine altezza
5099 Vistas
As the topic states need the torque specs as all im getting online are 3sgte specs. Didnt know these specs were so hard to find. Need for the timing assembly, crank pulley, flywheel. If anyone can assist please
Not easy to get and Japanese only.
Attached you’ll find some parts of the 98 Altezza 3sge engine manual.
I hope that helps.
  • File
Yeh that is my problem, only gett8ng japanese specs
