4 port and haltech
Control de impulso
3186 Vistas
hi guys, was looking at doing the Boost Control course, you guys have any plans to add in the 4 port boost solenoid and setup for the Elite...
thank you
There is nothing different in the tuning side of things for a 4 port solenoid compared to a 3 port - The 4 port simply expands the range across which you can control the boost pressure for a given wastegate spring.
As soon as we have the opportunity to do so, we will add a worked example on the Elite ECU. Unfortunately right now we don't have access to any turbocharged engines running on the Elite local to us.
