Apexi avcr install help
Control de impulso
1655 Vistas
Hi I was wanting to install apexi avcr on my car for boost by gear and electronic boost control. I need help with the pinout locations to make sure I install it right. Can you guys help me out? Here is a link to my pcm pinout
https://www.redlineforums.com/threads/ok-finally-the-pcm-cheat-sheet-better-be-a-sticky-please.4235/
