Best location Boost Port
Control de impulso
1627 Vistas
Good day,
I plan following sert up in order to being able to reduce boost while driving:
Super Charger
Tube to intercooler with blow off valve which is connected to manual boost controller
Intercooler
Tube to throttle valve
Intake manifold
Does it make a difference where the I take the boost value from? I could do it from Intake manifold or intercooler.
Thanks to you all.
