boost control read negative
Control de impulso
1695 Vistas
why my boost control read negative and boost duty cycle not reading ?
We need some more context to help you. What ECU / Software are you using? Can you provide a log showing the problem you are experiencing?
ECU type?
Engine conditions when this is occurring?
Some boost control systems will report a negative value when the control is not operating to ensure that the waste gate remains closed to assist in the building of boost.
