Hp tuner not reading my car
Control de impulso
2658 Vistas
I tried to tune my car but i can not read the pcm by hp tuner and I tried to enter manually also can not read it
What exactly is the vehicle? Using the VIN seems to give some conflicting details, depending on the application used to decode it?
Nissan patrol y62 v6
i used hp tuner. Before i took it to tuner shop to tune it and after that i return it to stock tune by the way he used hp tuners
Do you have the Scanner application open? You can only read an ECU/PCM from the Editor if the Scanner is not connected to it.
