Injector deadtimes for denso 23250-16061 (toyota 4AGZE)
Control de impulso
1225 Vistas
Can anyone help with the deadtime values for stock 4AGZE injectors? They are Denso denso 23250-16061 385cc injectors. Thanks
It's likely to be very difficult or impossible to find trustworthy dead time data for an old factory injector like this. While having correct dead time data is always our goal, sometimes it's just not feasible. If you can't find anything for these injectors then I'd recommend keeping the default dead time table shape and scaling the values up or down until you have the dead time at 14 volts at 1.00 ms. It will be sufficiently close to provide a good tune.
While this isn't ideal, to put it in perspective, when I first started tuning some of the ECUs that were popular at the time had NO dead time compensation at all!
Thanks Andre for your help, will give it a try then and revert on the values that work.
