Subaru RomRaider - Open Loop Boost Control setup
Control de impulso
2435 Vistas
Hi there,
I just finished the course and I'm ready to get my hands dirty and tune that boost.
However, I'm just not sure what is the best way to force open loop with the available tables in RomRaider.
I was thinking of setting Initial Wastegate Duty A/B and Max Wastegate Duty tables to "0". Disabling Turbo Dynamics by setting TD Activation Thresholds (RPM) to extreme high values.
Am I on the right track or am I completely off?
Thanks
Hey Julien,
I think it should work, if not, you can zero out the other TD activation tables.
