Supercharger boost manual boost control
Control de impulso
5657 Vistas
Hallo,
I need a simple solution for a supercharged engine. My idea. Add a blow off valve and manual boost controller.
Will this work?
A little googling shows that people do this. Here is a kit that might help you get started:
https://www.smoothboost.com/p-41-centrifugal-supercharger-boost-control-kit-by-smoothboost.aspx
I'm sure that set is working. I want to use a simple tial blow off valve which is usually used to reales boost when getting of throttle.
Any idea why it could not work?
Thank you
Work how? Allow you to run a higher boost pulley set then limit the boost. Yes I suppose it will do that.
I don't see how adding a blow-off valve will do anything to increase boost by itself.
Sorry, i need to decrease it. Looks like that will work. Thank you.
