Turbine thrust setpoint(kw)
Control de impulso
1352 Vistas
hi Ben,
Please help in adjusting Boost control- turbine thrust setpoint(kw)
i am adding the stock data. Here boost is set to 14psi.
Sorry i can't tell you what that table is achieving or what (if any) changes are needed. Please read my other reply to you.
