Antilag launch control
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
3624 Vistas
Hi guys,
I want to activate the antilag launch control without using speed sensor input, is it possible?
I am Haltech ps 1000 Ecu and i am thinking to activate the antilag launch control while rolling for ex. At any speed, lets say 40km i want to press push button then apply full throttle and go, any thoughts
Thanks
i would try to and set the speed to 0 and see if this deactivates the speed switch.
u will then need a switch be it clutch switch or a manual switch to activate and deactivate launch control.
i have not seen a work around for ps1000 and rolling launch control yet so if you have success let me know
